Hotlink Module
Simple example: 4 story building, all identical.
Can i hotlink 1st level and use the module IN THE SAME FILE for 2nd 3rd and 4th floor?
I have tried saving the 1st as a mod file, and place it on the other floors, BUT now when i modify the 1st, the others will not update.
2 Replies 2
Did you re-save your MOD after changing the 1st floor plan?
As soon as i found out more about the Hotlink Manager,
And as soon as i resaved it with the same name,
It worked.
I was afraid i have to always edit it manually in other file...
Thank you.
