2007-05-09
08:45 PM
- last edited on
2024-07-09
08:52 AM
by
Aruzhan Hamar
2007-05-10 11:45 PM
2007-05-11 08:42 AM
s2art wrote:I have had a similar experience to what you describe Stuart.
I just encountered a case where a particular Layer Combination wasn't sticking. I'd select the combination (one that has resided in my Template file for donkey's years), the layers changed, but the Navigator Properties and Quick Layers both displayed "custom". Strange.
So I went to the Layer settings, (no layer combination was highlighted, as in Wally's case), selected the Layer combination, picked a layer at random and turned it off then on again, and updated the Layer Combination.
It now works fine, shows the right layer combination in navigator and quick layers.
2007-05-11 07:27 PM
Barry wrote:I have seen the Quick Option state "Custom" for many of my saved views. In the Navigator View Map, the Layer combination shows correct though. Opening the Layer Dialog box shows that the Layer combination is not actually highlighted, and if the layer combination is selected the one layer that seems to show on is the " ArchiCAD - master only" Layer. Even with out doing an update of the layer combination, the view now states the proper layer combination in the shows correct in Navigator view map and the Quick Option. Strange. It seem that just opening the Layer DBX sets it correct.
So maybe it would be a good idea to check that the correct layers are actually still on.
There may be one that you haven't noticed that is turned off.
2007-05-14 04:33 AM
2007-05-15 12:59 AM
Kristian wrote:putting aside thoughts concerning add-ons writing attributes without the user's say-so, cadimage did acknowledge this as a bug and fixed it with patch some months ago now. downloading and re-installing their latest batch of tools should fix things.
I've found a work around for this.
In the folder - C:\Program Files\Graphisoft\ArchiCAD 10\Add-Ons\CadimageTools - is a file MasterLayers.ini
This contains the ArchiCAD - Master Only layer string.
I simply deleted all strig and saved it and have had no issues since.
2007-05-15 01:21 AM
s2art wrote:So logical, but not what I did. I re-built
