Toilet layer
"You may place the wrong layer..."
but actually i put all the layer right. what's wrong with the toilet and basin ....?
EY
5 Replies 5
__archiben
are you for real?
b e n _ f r o s t
YES, sometimes when i turn to elevation or 3d the screen popup to show you that " you maybe placing the incorrect layer...." but i just click ok.
EY
__archiben
oh. ok.
b e n _ f r o s t
There is a wrong layer macro in some of the Australian library parts. If you don't use the 'standard' layer set they are rather annoying. Best thing to do is open the object and put a ! in front of the lines using the macro in the master script (or just delete everything in the master script). You will have to unpack the library first.
could you tell me what do you mean the "standard" layer, if i do not use it, what can i use?
EY
