Project data & BIM
Uniform layer
I remember there was a function allowing the user to use same layer for each drawing tool used... "Uniform layer" or something like that.
As I haven't been using Archicad intensively since 3 or 4 monthes, I can't remember where I had found this option....
Any idea ?
Link
Options>Layers>Active Layer.
Link.
Thanks Link,
I was searching in Window -> Floating palettes...
Let's hope AC9 will be the complete interface redesign version...
