Martine1
Work enviroment
Hi! When I start a new project I get the option to browse for the right template. This works and everything is right. But when I am going to choose "work enviroment" the right one does not show. There is no place to browse for it. No button to click on. I have the right one on my mac but I have no way of choosing it... What do I do?
1 Reply 1
What version, localization and build of Archicad is this happening in?
With Archicad 26 USA build 4022, I see all named WE's in the drop-down as shown below.  Note that the previous WE is always loaded by default, so typically there is no need to select a new one.  Note also that if you have not saved each section of your WE with a name, and the entire collection of schemes as a named WE, then it will not appear (or work properly) in the drop-down.
