Ugljesa Janjic
dwg x-ref not visible
Hello and please help me with this:
I am trying to x-ref a dwg file into a worksheet to use as a trace and it is not visible. The x-ref manager says that it is there but I can't see it. I unlocked all the layers both for the drawing and the x-ref and all and I still cannot see it. I zoomed to extents and the zoom changes as though something should be there but, yes, I still can't see it.
I can't think of anything else.
Do you know where my problem is?
Thank you very much!
Ugljesa Janjic
[email protected]
ArchiCAD 25
Mac OS
I think that the problem is in the DXF very large coordinates. Try to use the command Edit/Select All on the worksheet.
Ugljesa Janjic
Thank you for your reply,
You know, who knows what it is. I tried what you said and nothing is selected.
I opened a new project and did the same thing and it worked properly just like it should.
Then I went around it by going back into my original file and using Place External Drawing (the same dwg file) command instead of x-ref and it worked perfectly. So the only difference is that if the subs change their background I will have to update mine. Not a big deal since it is a small project and I don't expect to be changing anything soon.
Not worth wasting time.
Thank you again for your help!
Ugljesa Janjic
[email protected]
ArchiCAD 25
Mac OS
