Achille Pavlidis
Hotlinked PLN on TW project doesn't update
We have a PLN file hotlinked to a TW project, when we change things on the PLN file, and then go to the TW project hotlink manager the PLN appears as "modified", but after clicking "update" the changes are not reflected to the TW file. The process seems to work, the hotlink appears up-to-date, but the version shown is the old one...
Anyone else having the same issue???
Mac OS 26.4 | AC 29.2.1 INT 5101 FULL
Rick Newton
I am having a similar problem, but it is only happening with SOME of the dimension strings, or PART of a dimension string. Very strange.
Rick Newton, Architect, ArchiCAD 17, 27" iMac:•3.4GHz Core i7 •32GB 1600MHz DDR3 SDRAM-2X8GB •3TB Fusion Drive •NVIDIAGeForce GTX 680MX 2GB
