2019-09-27 03:03 PM
2019-09-27 04:29 PM
Noémi Balogh
Staff Community Expert, Admin
2019-09-27 05:28 PM
nbalogh wrote:Thanks for the reply!
I don't know your current setup's details, though, this is what I would recommend you to follow:
0. Send & Receive in all projects you are currently joined with any of the users.
1. Export projects, libraries, users and as optional, roles if you changed any of them from the current BIMcloud Basic.
2. Install the new BIMcloud Basic - can have any name or port, just make sure it is accessible - should be a Fully Qualified Domain Name or a static IP and should be accessible from external network too, since you plan to move to the site as well.
3. Import projects, libraries, users and roles to the new setup.
4. Continue working - users must re-join to the new BIMcloud Basic with all projects.
In this case, normally you don't need to change anything, the only problematic thing can be if you have Teamwork hotlinks or external drawings - then they should be re-linked from the new BIMcloud Basic.
This is the easiest way - if you follow this, it is hard to go wrong. : )
Kind regards,
2019-10-03 02:56 PM
Noémi Balogh
