vfrontiers
Object Size limit?
Just wanted to know if there is a size limit for an individual file for uploading in a BIMSERVER LIBRARY..
I have a PROJECT LIBRARY that has and aerial photo that I need applied to a picture object... If I remove the JPG from the library it loads fine... if I add it back, it shows errors and the jpg is not available.
I've reduced the filesize down to 768k and it still has issues... (REFRESHING BIM SERVER LIBRARY)...
I don't believe there is any other way to have this TW project load with the aerial on the picture object (e.g., I can't have the JPG as an EMBEDDED Library part)...
Anyone?
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
0 Replies 0
