Project is not saved. Teamwork
Changes not saved in teamwork. https://ibb.co/dK0t2q4
3 Replies 3
Hello henckok,
You had to describe the problem a bit better and express it in english* so that we could understand and then help you. Do you check the quality of your internet or intranet connection ? Do you have enough rights to modify the teamwork project ? Is this technical concern new or has it always been ?
*I'm french
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
henckok wrote:
Changes not saved in teamwork. https://ibb.co/dK0t2q4 - Вот такая вот ошибка, при попытке засейвить проект в тимворке, что делать?
Translation ...
Here is such a mistake, when trying to save a project in teamwork, what should I do?
Sorry I could not translate the error message ...
And I don't use teamwork so have no answer for you, but someone else may know what this is about.
Noemi Balogh
Hi henckok,
As far as I can see, ARCHICAD offers you to reload the project from a recovery file.
Reason can be a corrupted GDL element, a corrupted stair or railing, or any other element.
What I suggest:
1. Save a PLN
2. Open the PLN with Open & Repair
3. Save the result with Save as...
4. Open the repaired project
5. Re-share it on BIMcloud
6. If still no luck, contact your local GRAPHISOFT representative for support
Kind regards,
Noémi Balogh
Staff Community Expert, Admin
