Can't creat VR Object in ArchiCAD 13
I recently started using ArchiCAD 13, and when I try to create a VR Object in 13, it tells me "To create VR documents, place the VR Engine into the Add-Ons folder." I create these with ArchiCAD 12 quite often and it works fine.
I found the QuickTime VR Engine in the Visualizations folder in the Add-Ons folder for AC12 and copied it into the AC13 folder, but it still didn't work.
Has anyone else had this problem? If so, how do I make it work in AC13?
1 Reply 1
Hi Anna,
See the post by Gergely on this page - http://archicad-talk.graphisoft.com/viewtopic.php?t=30298
The direct link is - http://www.graphisoft.com/support/archicad/downloads/ac13/QTVR.html
