Jake
Enscape with Archicad Issue
I am experiencing an issue where the model created on Archicad (version 25 solo) will not appear on Enscape when I run the rendering engine.
Is there a diagnosis for this?
Thank you
5 Replies 5
scottjm
Mentor
I would attempt marqueing a smaller area of individual elements to see if they come up in Enscape.
Is the issue only present in this model, or does it also happen with a brand new file with only a couple of 3d elements modelled?
Patrick120772
In enscape change the perspective view to orthogonal...or 2 points perspective. It happened to me sometimes with AC25...now with AC26 it didn't happen yet
Jake
Thank you Patrick, I tried this, but the same result unfortunately.
Jake
I did what you said, and the model still did not appear. The issue is present for the current model, but also for new files I create.
However, Enscape sent me an email, mentioning that my graphics card is not supported by Enscape. So I think that may be why.
I do not have NVIDIA or AMD. Just Intel.
Would this be the reason why the model is not appearing in Enscape on AC when I run it?
Patrick120772
probably
