Visualization
HAVING PROBLEMS RENDERING
I am having difficulty getting my material to render correctly on the cylinder shape. When making an object i used the cylinder basic shape in archicad library 10 to help form the object. I'd like the object to render a crocodile material and when i render the cylinder renders brown the rest of the object renders ok? I have checked that the material is set for crocodile material and in fact the whole object should be crocodile. Can some one please advise me..
Thanks
s
1 REPLY 1
Simon,
What rendering engine are you using? If you can post an image of what you are getting from the render.
