How to apply arroway texture into archicad rendering?
I have problem when rendering in archicad not realistic due tile texture, how or can arroway texture apply into archicad rendering?? tq in advance
It is pretty easy to do using the arroway diffuse map (the one ending in d). Do you know how to edit AC materials? I could walk you through it but may be easier to look at the user manual or other tutorial.
FWIW, I've found some really nice tile textures at http://www.porcelanosa-usa.com/. I often end up speccing tile from them as well.
http://archicad-talk.graphisoft.com/viewtopic.php?p=204945
