Visualization
How to show floor plans with sketch type lines?
Hi all - I was wondering if there is a way to show a floor plan with the walls and windows set to look more sketch like. I love the program so far but I'm struggling with a way to present initial floor plan concepts that don't look too finished/final. I would like to show the walls (interior and exterior) and the doors and windows in a more soft/sketch like way. I figured out how to do it with regular lines and shapes by just changing the line type but I can't figure out how to do it with the walls, windows and doors. Thanks for any help, tips, advice - much appreciated!
8 REPLIES 8
David Maudlin
SJPHouse:
I did this using Graphic Overrides for the wall, windows and doors in AC 21, should be the same in AC20.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Thanks David somehow I missed this reply awhile back I will try it.
Tendenz
David wrote:
SJPHouse:
David
David, could I please trouble you for a screenshot of the Graphic Overrides rules for this?
iMac OS X 11.6
2,3 GHz Intel Core i9, 16 GB 2667 MHz DDR4
ArchiCAD 25
David Maudlin
Tendenz:
See attached screen shot. Then create a GO Combination that contains this rule.
David
Hello,
I`m new to the Archicad Community and wonder:
How do you make the linetype "sketch"?
(I know how to make a custom linetype, but not how to make one resemble the sketch shown in this tread....)
Thanks in advance.
Anders.
David Maudlin
Anders M:
First try opening a template file and see if a sketch line type is there, it can be moved to your project file with the Attribute Manager. If not, then just use the Polyline Tool to create your own.
David
Just to clarify a little.
Create a polyline you want for the sketch line in plan.
Select and copy it and then create a 'Symbolic' line - pasting that polyline in for the pattern.
Thanks David & Barry!
Found it in the template file!
Anders.
