Visualization
Own materials application
Hi
I have created a texture for a wall in my design, and loaded it into archicad using the 'materials' settings. I have created it at exactly the correct dimensions yet when I apply it to a wall surface it goes wrong.
I have attached two pictures, the top one is of the texture (logo) i want to apply and the bottom is the resulting effect. Somehow when I apply it, it seems to apply it from the center of the wall and wrap around, rather than starting at the one end and applying it to the other.
I have fiddles with all of the material settings and I can't figure it out.
Many thanks,
Emily
1 REPLY 1
Go to:
Design > Align 3D Texture > Set Origin
For walls this is best done in the 3D window.
