Sketch render settings
Can I save sketch render settings? Why do I have to experiment with the sketch renderer every time I use it. Why can't I save my trial and error work?
Dwight
You'll always do better here by starting a question with "How do I" rather than "Why won't it.
Saving a rendered view to the View Map preserves its settings. You can rename the view to suit.
The current Sketch setting appears in a text file:
Inside Add-Ons\Visualization\SketchTextures there is a text file called
SketchPreset.
You can cut and paste this file and keep it for later...
Dwight Atkinson
Thanks for your help I will try this out.
