Wireframe Render
Is it possible to render the wireframe of a project?
Cheers
5 Replies 5
Dwight
Yes.
By specifying "Wireframe" in either internal engine or OpenGL rendering.
Dwight Atkinson
Maybe I'm missing something..
When specifying wireframe in the 3d view mode tab, I see my model wireframed in the 3d window, which looks bad when printed (antializing looks bad).
Is there a way to see my lines nice, smooth and straight?
From 3D window save the View in the Navigator, then open a new Layout and place the view there! Adjust the Scale and Pen Set! Then print the Layout! You will have to wait for the regeneretion of the model each time you open the Layout though. 😉
__archiben
LukasB wrote:
I see my model wireframed in the 3d window, which looks bad when printed (antializing looks bad).?
use the internal engine rather than the openGL engine. archicad's openGL implementation is great to work with because it's quick. but it's pretty limited in its quality. archicad's internal engine is painful to work with because of it's speed, but its linework is far superior . . .
~/archiben
b e n _ f r o s t
thanks for the tips,
Lukas
