painting queries
I Have a few queries regarding painting.
1)How to paint a wall with 2 or more colours?
2)How to replace a whole painted structure with another paint?
3)Is it possible to use paint shades from jpeg image file or shade cards from paint manufacturers website?
thanks
8 Replies 8
Dwight
1: like a wainscot [horizontal band]?
- use complex profile, OR wall accessory panel feature.
2: Find and Select by material. Re-assign materials one tool type at a time, OR create a special new material that changes in the material dialog to test different colors.
3: don't use paint shades as jpeg. Use a photo editor to sample RGB values from the paint samples and write them into the color sampler.
Dwight Atkinson
How to paint\write test?
Text and symbols like directions for tolilet,reception etc.
thanks
thanks
Have you tried the "3Dtext" object?
thanks
In which toolbar\menu this tool is avaliable?
thanks
"3D Text" is an object from the standard AC library, so use the object tool and do a search for 3D text.
I selected the object tool and searched through the archicad libarary.i could ony find 3d dimensioning.
can i get the full path please?
thanks
From the Object Settings select Find Library Parts. See Image.
thanks
