realistic lighting?
Hi
We're just starting to play with proper rendering in AC10.
The lighting looks terrible. Any tips on getting more realistic lighting? The lights available in the library seem very limited.
TIA
Adri
31 Replies 31
__archiben
andyro wrote:
I'll have to mess around some more before I know what I am dealing with....
i did have to give most of my materials a wee diffuse and/or specular boost . . .
also - your sun, its contribution to ambient and ambient intensities do come into play from with the 3D projection settings>'more sun' dialogue. and you have to be really careful doing this since there seems to be a bug that creates a weird green/yellowness if you get the wrong combination of values! see below!
dwight has an AC10 update for those who registered their 'lightworks...' book.
~/archiben
b e n _ f r o s t
Dwight
Ben:
what are the sun and ambient color values for the lime green popsicle look?
Dwight Atkinson
__archiben
sun - RGB, 254, 255, 244
ambient - RGB 242, 239, 255
but it doesn't seem to matter too much: whenever ambient hits somewhere between 60-70% (+ o r- a couple), the total light value goes nuts.
contribution to ambient also plays a part . . .
trouble is - as soon as you hit this strange light effect, anything over and above those values creates a weak, dull light. i've never reported it because i'm never really 100% sure what i'm doing!
ben
b e n _ f r o s t
Dwight
Perhaps you should switch your avatar back from negative land and your color representation will get fixed.
Here's my test of your wierd result - using exactly your color values.
You must have something else crude-euphemism-for-intercourse'd up.
Dwight Atkinson
__archiben
what happens when you use exactly my light intensity values too?! (put your sun up to 84 )
(look at the effect of changing my location and date to match yours...!)
b e n _ f r o s t
Dwight
sez 64 in the dialog.
here's 84.
sort-of wired but not psychedelic.
Do you give your machine drugs?
Imagine weed for computers. Slow that processor right down.
Dwight Atkinson
__archiben
sure?!
here's 84.
right. now click your ambient up slowly . . .
really weird too. see what happens when you click ok . . .
b e n _ f r o s t
Dwight
You have me on this one - this is clearly a wierd bug.
But while yellow is strange, that lime green is truly unexpected.
Dwight Atkinson
__archiben
can i ask what settings you would typically use?
b e n _ f r o s t
Andy Thomson
Mentor
What specific influence does location have besides latitude? Is there someone deciding what the quality of light in Abu Dhabi, Blenheim or San Francisco is?
Andy Thomson, M.Arch, OAA, MRAIC
Director
Thomson Architecture, Inc.
Instructor/Lecturer, Toronto Metropolitan University Faculty of Engineering & Architectural Science
AC26/iMacPro/MPB Silicon M2Pro
