some .lwa shaders does not appear..
I have downloaded *.lwa libraries from http://www.lightworks-user.com and put them in the right folder. Most of them work fine but some seems to be empty when try to open it in the material setting dialog box. Anybody has this problem?
Greetings
2 Replies 2
Dwight
the archives aren't materials.
You must load them from the archive into existing or new materials.
Some archives are not yet enabled in ArchiCAD because of licensing issues.
"Special effects" being just one of them.
Dwight Atkinson
Hi. What I ment was that some lightworks shaders are not avaible under the "Load settings from archives", see attached picture. They are not special effects or HDRIs just simple carpet and paint materials, are they also disabled because of the license you mentioned? Strange..
