where are the LW sun,sky,and window objects in AR 11 ?
Hi i have another little problem with version 11 ,i dont find the lightworks sun,sky ,and window objects , on the light sources , where are they ?
plk
7 Replies 7
Dwight
Archicad Library 11>LightWorks Lights 11:
as lamps....
Dwight Atkinson
Hi Mr Atkinson , thanks ill be looking for it .
thanks
Dwight
You do have a hard drive search function or is that only on Mac?
Dwight Atkinson
it is only on Mac , but i just have found the ligthworks file , and all is fine now.
thanks
Just to clarify, there is a hard drive search function in Windows. And if we're talking about searching within AC, there is also a "Find Library Parts" option in both Lamp Default Settings & Object Default Settings dialog boxes (both features are available in Mac and Windows platform).
Hi Junior , ill check hopefully it will be there .
thanks
You're welcome 3djunior.
