Affected version(s): ARCHICAD 22 | Severity: workaround applicable | ID: 258003
Issue
The ‘Publish BIMx Hyper-model’ function is greyed out in the File menu, ‘Upload BIMx Hyper-model’ cannot be selected as Publishing method, and BIMx cannot be selected as an output format for Publisher Sets.
Cause
The BIMx Add-On cannot load during starting ARCHICAD because one of its prerequisites is missing. This is Visual C++ Redistributable Packages for Visual Studio 2013 which is not installed during the installation of ARCHICAD 22.
Solution
Install the missing prerequisite of the BIMx Add-On. The VCRedist 2013 installer can be found
on this site. A restart of ARCHICAD is needed after the installation.
