2D Cutting Planes
WAJ
The same functionality of 3D cutting planes, but for GAs, elevation etc. - or even be able to use the same cutting planes set up in 3D, in 2D.
You could then use it to define the visible area of the view and have the them auto-update on the layouts to avoid changing each drawing size.
3 Comments
What is a GA?
Elevations and sections are already limited in width by the position of the marker and limits on the heights can be set in the section/elevation settings.
So they effectively have horizontal and vertical cutting planes already, you just can't cut on an angle.
Or maybe I misunderstand what you want and you could show a sample image?
WAJ
@Barry Kelly Sorry, I mean for Plans (GA/General Arrangements). I essentially want to be able to set/choose a visible area of the plans without having to use layer combinations. Essentially cropping the saved view of the plan without manually doing it on the layout page.
2D
Status
Submitted
with 3 Votes
Wish details
