Ability to show zone dimensions in zone stamps, width x height (X x Y) of zones geometry in plan
Stockholm
Ability to display zone dimensions in zone stamps, showing width × height (X × Y) of zone geometry in the plan.
This is especially useful for early-stage floor plan design proposals. It provides valuable information for clients, helping them understand room sizes instead of just estimating how large the spaces are.
Ideally, this should also be available as a property, allowing dimensions to be displayed in regional versions of zone stamps, etc.
If the zone is not rectangular. There should be 2 different ways to show the dimensions. Either the smaller values och either the larger values. That could be two different properties for zone dimensions for example.
1 Comment
nbrauer718
Twenty one years later, and still asking for the same thing!
https://community.graphisoft.com/t5/Documentation/Create-a-Zone-stamp-that-lists-room-dimensions/td-...
Code in thread above worked, but I've moved away from using Zone Stamps, replacing them with labels. But if we could add the code to a label, it's not bad.  Moving (2) hotspots to define dimensions is better than stretching (4) line end
points.
Status
Open
with 1/200 Vote 200%
Wish details
