Archicad to DWG/DXF - extra translation options
magkuj
Hi everyone,
I’ve encountered a couple of issues while exporting files to DWG, and I couldn’t find relevant options in the translator settings:
  1. When exporting from a layout using the Paper Space with Cropped View’s content option, I noticed that certain auto text elements inserted into the title block - such as the drawing number, scale of placed drawings, and layout name - don’t export. To avoid duplicating the title block across dozens of drawings, I draw the title block in the 2D workspace and place it in each layout template (usually I have tens of sizes). Most of the title block content is set as auto text based on project info, and that part exports to DWG correctly. Given the large number of drawings, sheet sizes, and varying scales, this export method (Paper Space with Cropped View’s content) is the most efficient for me. However, I’ve noticed that this issue doesn’t occur when exporting to Model Space.
  2. I’ve developed a system for marking wall finishes using custom symbolic lines. Unfortunately, these lines don’t export to DWG, regardless of the translator used. Would it be possible to add an option to convert these symbolic lines into blocks in DWG - either by exploding them or enabling easier export of custom line types?
Thanks in advance for any tips or solutions!
Status
Submitted
with 0 Votes
