Converting Template to Use the Global Library
Jackson Han
Hi Team,
We need support for batch migrating templates that use Archicad libraries from version 27 or earlier to the Global Library.
The advantages of the Global Library are clear:
  1. There is no need to load libraries when continuing a project.
  2. There are no issues with changes in library reference paths.
  3. There is no need to migrate libraries in Archicad versions 28 and later.
As a result, the process of converting existing templates to use the Global Library will inevitably occur for Archicad users.
However, as far as I know, there is currently no support for migrating individual objects and attributes—except for Favorites—and if I remove the Archicad 27 or earlier libraries from a template and load the Global Library instead, some references may be missing.
If users have an extensive template, rebuilding it from scratch or manually mapping it to the Global Library would be highly inefficient.
Therefore, I believe a feature to assist with this process is necessary.
I kindly ask for a positive consideration regarding the development plan.
Best regards,
Jackson
Status
Submitted
with 0 Votes
Wish details
Product
Labels
