Custom profile definition with Morph tool edge/line statuses
Ville
Hello!
Profiles need a feature upgrade to support level of detail and visibility of their nodes and edges like the objects/morphs have. At the moment GDL can't define profile attribute either.
What we need is:
-Settings in profile manager to set visibility of line/edge generated by each profile node
-Setting resolution levels/steps for curved elements, in profile UI. Steps meaning predefined alternative presentation accuracies.
-Support for controlling detail level (accuracy) of components using profile-attributes in Display options
-Ability for GDL-object to create and merge smart profile definitions to projects
The attached screenshots of existing UI show where to place these settings.
Hope You like this idea!
Ville
1 Comment
NBGheikki
The end result could be something like this. Below is what a complex handrail looks like out of the box – it's very dense and will not look very nice in a section or facade. Above is what it could look like if we could adjust how each vertex of the profile acts. (I made these adjustments by turning the handrail into a morph.)
Status
Submitted
with 7 Votes
