Cutting Planes - Deactivate Instead of Delete
hevi
Ace
It should be possible to deactivate cutting planes instead of deleting. Switching between a cut and uncut view is common while modelling in 3D but currently is is only possible for all or none of the cutting planes. Instead there should be an UI which list cutting planes created for the view and a toggle for active/inactive.
Often there is one or multiple general planes that defines the scope and that is more static relative to the view and a set of planes that gives the specific section of interest and which is more dynamic while modelling in the view. Eg. vertical planes that cuts out the facade and horisontal planes for each relevant height. It should be possible to quickly go through such horisontal planes without redefining them.
Status
Submitted
with 1 Vote
