Doors in Archicad have built-in Leaf Dimensions and Egress Dimensions parameters that are available for scheduling, but are not exposed to the Property Manager's Expression Editor, there is no way to automatically reference these values within an expression-defined Property.
I would like these properties to be made available for expression-defined Property expressions. I would like to set up automatic checks in Part-M and Part-B, for the minimum effective clear door width, the number of hinges based on the size of the door leaf, and other properties. As it it, this expression cannot be automatically set up when using doors with side panels or fanlights, even thought the the information is available in the interactive schedule.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
