IFC Translators Settings as JSON
Nader
I´m asking that all settings related to IFC should be saved as JSON files, and not just as .tpl, pln and/or PLA only.
In the current way you can only save the settings as mentioned, and can only export Type Mapping and Property Mapping Settings as xml (also would like to see them in JSON files).
I would like to see this change in a similar way to how Work Environment Profiles are set, saved and restored
1 Comment
scottjm
Mentor
+1 for this.  I recall we used to previously have the ability to export the whole translator as an xml, but no longer.  It quite cumbersome when you know you have the a whole translator setup exactly as needed in a teamwork file and need to transfer it to another file.  I have save off a pln and then open that pln through the new file translator.  can be very slow if the original file is large.
Status
Open
with 7/200 Votes 28.571428571429%
Wish details
