Import/export toolbars and menus between Command Layout Schemes.
We need to be able to import/export toolbars and menus between Command Layout Schemes. Every time I migrate to a new version I either need to rebuild all my custom menus and toolbars OR carefully add all the new toolbars and menus to my previous WE. It's insanely annoying and a waste of time. If I could just import my toolbars and menus into the default Command Layout Scheme, I would save SO much time every version. It'd also allow me to better customize Archicad because I wouldn't be worried that I have to redo work every year.
2 Comments
SeaGeoff
Ace
I just copied 6 toolbars from on profile to another by cracking open the exported XML files and C/P select lines of code from one to the other. It was technically easy, but geeky AF, and very easy to mess up. So I don't recommend it for most users. But does prove how easy this would be for Graphisoft  to implement.
scottjm
Mentor
I have done a similar thing with transferring workspace settings to new version via xml.
The tricky thing is sometimes some toolbar and menu functions have changed guids between version.
Status
Submitted
with 12 Votes
Wish details
Product
Labels
