Improving the Site Plan Workflow
Davy NOEL
Would it be possible to improve the system for creating site plans, which remains incomplete to this day? Several methods coexist, but none are fully satisfactory.
Method 01: Work on the floor plan and show the roofs. Advantages: Roofs and terrain can be dimensioned. Disadvantages: It is complicated to show roof accessories (such as gutters) and all protruding building elements (balconies, canopies, etc.).
Method 02: Work on the 3D document. Advantage: Everything that needs to be visible is there. Disadvantage: It is difficult to correctly dimension (in terms of elevation) the project.
Method 03: Combine both solutions using a working sheet. Advantage: Aesthetic plans and dynamic information. Disadvantage: The plan does not follow modifications and requires more steps.
Since you also use Revit, wouldn’t it be possible to create a dedicated view system inspired by Revit—a kind of dedicated view?
Status
Submitted
with 3 Votes
Wish details
