Description:
When a new index is created for a specific plan and then closed, it is no longer possible to assign the same index later to other layouts that were not yet updated or included at that time.
Details:
In practice, not all layouts are updated at once. Some layouts may be delayed or modified later within the same revision round.
The current system does not allow reusing a closed index for layouts that were left out initially, which results in:
The need to create unnecessary additional indexes.
A lack of consistency between layouts that belong to the same revision or planning phase.
Extra manual effort and reliance on workarounds to maintain documentation.
Requirements:
Allow reusing a closed index for other layouts that have not yet been assigned to it.
Make index management more flexible and layout-dependent.
Maintain consistent index tracking without forcing redundant index creation.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0 Votes
