Interruption of cloned status of the existing Cloned folder in Navigator View map
Feek
It would be nice to be able to simply cancel the clone status of an existing cloned folder in the View Map.
By default, folders such as Floor Plans or Sections are cloned in the View Map. This has its advantages, but if you want to change the hierarchy within these folders, you can't - only the standard folder allows this. So if I want to work more freely with the Views within the folder (for example Floor Plans folder), I have to first create a new parallel standard folder for the given default (cloned) folder, then copy (duplicate) all Views from the default cloned folder into it..., and then delete the entire original cloned folder, including the original views.
But this is unnecessarily complicated and time-consuming. I would really like to be able to mark a cloned folder and after right-clicking on it to have the option to "cancel cloning" in the menu.
Status
Submitted
with 2 Votes
