Label size - keep when editing text
P W
When I place a normal label with a note (wrapped text) and later go back to edit the note it nearly always changes the box to one long line. We have a specific office standard width for notes and it would be nice if they stayed the same width that they were resized to the first time.
No image - because of course it won't happen when I want it to!
However; that does NOT mean I'd want a change to a locked width that is changed by going into settings as often I'm in different scale drawings and it would be annoying to have to reset it every time. It's much quicker to do it graphically with a hot spot.
1 Comment
Lee Hankins
I have noticed this too. It seems to be because the ‘wrap’ option turns off as soon as you click to edit. If you select the label and then make sure to reselect wrap again before click to edit the text will retain the wrapping. It does need fixing though and a fixed width setting would be great.
Status
Submitted
with 3 Votes
Wish details
Product
Labels
