Layout Subset Name Depth
Guru
https://community.graphisoft.com/t5/Documentation/Index-how-to-choose-the-right-subset-to-appear-on-...
Hi all,
Can we get the option to specify the depth of the Layout Subset Name autotext?
Project Name
T1 Subset Name
T2 Subset Name
Layout
T2 Subset Name
Layout
T1 Subset Name
T2 Subset Name
Layout
This is more relevant now with the introduction of Design Options where you may want a set of drawings for each option with a different title.
Alternatively, the a variation of the autotext Design Option Set Name could be made to act much like the Drawing Scale autotext where it will read all options on the layout.
Ling.
5 Comments
mtjcs
I would like to request the addition of hierarchical subset AutoText variables, specifically a <Top Subset Name> or <Subset Level 1 Name> tag (and ideally tags for each level, e.g. <Subset Level 2 Name>, etc.).
Currently, <Subset Name> only returns the name of the immediate parent subset of a layout. This is insufficient for workflows that use nested subset hierarchies.
Thank you!
GG_rakurs
"Subset Level n" is actually a great suggestion.
Guru
I made an identical wish a month previous.
https://community.graphisoft.com/t5/Wishlist/Layout-Subset-Name-Depth/idi-p/692201
[Moderator: I merged the two wishes now as well as their Votes.]
Guru
Creating folders within each drawing type for each Design Option is so backwards... but alas, you cannot organise it by Design Option, then drawing type due to the lack of depth... RIP automatic numbering...
Guru
I was just considering a move to a PMK workflow to reduce the time it takes to print a set in a project that currently consists of 14 pln files, but have stumbled into this dilemma again... I guess I will go with Edwin's workaround and reference the Master Layout Name...
Status
Submitted
with 10 Votes
Wish details
