Hi all,
Recreating a wish that has been purged from the system... since I have been running into this issue more and more frequently recently...
I tried some times to find if it is possible to set conversion table to not export some Archicad Fills. Now I got the answer from Laszlo Nagy that it isn't, but I think it could be a useful option in many case. So I ask to add the ability to map to "not exported" any of the attributes we already can map to a specific Autocad attribute.
Seems not to much complicated to do...
IDEA-11937
Having your drawings become monochrome blocks is beyond useless...
Ling.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0 Votes
