Live Properties Palette
MERLO
Hello, I think that by 2024, most users rely heavily on classification systems. That said, I can’t understand why we still don’t have a built-in properties palette included with the software, without needing extensions like the Live Palette from BIMdots. The same goes for a layer palette with the simple option of updating/overwrite a combination without the need to create a different one.
Adding such features seems simple and would likely be appreciated by everyone. 
1 Comment
rakurs
Also, it would be AMAZING if we could see what properties are different among selected elements! You know, like, whatever Autodesk has going for themselves since... always. If there's a shared property between selected items, and the property has different values between them, AutoCAD specifies "VARIES" in the value field. That way I know the selected doors are not the same and I should be careful if I change the property! And when I see a non-"varies" value, I know that all the objects share it. It's such a common sense addition I simply cannot believe that it's not a thing.
Status
Submitted
with 20 Votes
Wish details
Product
Labels
