Straight pipe has fixed values fot MEP symbol fill , pen and pen2. It would be very helpful if I could set a different colour in the route settings. It is important because now I can barely see the difference between 2 MEP systems of vertical pipes.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 3 Votes
