Magic wand - keep outer and inner contours
2D
It often happens to me that i want to add via magic wand to the outline of a slab, fill, mesh, roof to another slab, fill, mesh, roof which has openings or holes within and i always end up having to redo/substract the holes.
  • it would be amazing if you could at least tab through an outer and outer + inner contour configuration when using the magic wand
  • it would be great if useless (collinear)  control points are automatically removed in the process. Currently if using the wand to add to an existing shape the intersection of edges generates control points which 99% of the time are only adding to complexity.
Status
Submitted
with 6 Votes
