In lieu of typing in custom dimensions to cover up minute fractional dimensions (whether due to sloppy drafting or odd geometry), it would be helpful to have a dimension-style override setting for a particular dimension label. I'd rather assign a dimension style that stops approximates to 1/4" increments to correct a rogue 1/64" of in inch rather than typing in a static dimension that might change.
A visual pen change for overridden dimensions would also be helpful with this functionality.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0 Votes
