Pocket Door Cavity Pen
Guru
Hi all,
Since I ran into this issue again, a simple wish.
https://community.graphisoft.com/t5/Libraries-objects/POCKET-DOOR-LINE-WEIGHT/m-p/288057
Can we unhide the Cut Line Pen (global: WALL_SECT_PEN) parameter for non-basic walls?
Ling.
3 Comments
Stefan L_
While we are waiting...
Can't you go the 'Ctrl-Shift-T' way? Dunno the INT naming, it's this one here:
BTW, I'd extend this to:
"Could you please stop hiding any parameters? My elements 'use' attributes they don't use at all..."
Stefan
Guru
"Edit Selection Set". I have not actually used that since my initial introduction to AC... Thanks for the workaround. Wonder how it actually works since the one pen setting on it can change multiple pens. SECT_PEN for WALL, COL and SLAB but not beams, as well as the FILL_PEN for them.
I did consider expanding this wish to that, but a lot of that is object bases which is a much larger update than a single toggle in the tool itself for this global.
Ling.
Stefan L_
This pen once (dunno, AC-7-ish?) was officially called 'primary pen', other pens probably are the result of 'incremental engineering'. 🤣
Still applies to wall reference lines btw.
Status
Submitted
with 0 Votes
Wish details
