Hi all,
This wish is for a 3D MVO Override for the Railing Tool.
This is especially important due to all of the use cases for the tool outside of creating balustrades. We were given the option to override the 2D when the tool first came out, so why not the 3D? One major annoyance with the current system, is that you may have a "railing" that does not contain a panel, but it still gets simplified to flat continuous vertical plane...
Ling.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
