I use the Re-size tool often, but I find it restricting that the aspect ratio is locked. I would like to be able to re-size in one direction, or even better to resize as a trapezoid. I often work with drone photos or areal photos which are distorted and could correct that distortion with the re-size tool. Currently you only have one option to make it bigger or smaller but no way to distort the image.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0 Votes
