Reporting of openings on the correct floor
MCP21
Scheduling Openings (Doors & Windows) to the Correct Home StoryProblem Description
When creating Door and Window Interactive Schedules, the "Home Story Name" (or "Home Story") parameter reports an incorrect value compared to where the elements actually belong.
This issue occurs in a split-level / staggered-floor project consisting of two building sections where one section is vertically offset from the other. The Story Elevation is defined at the finished floor level of the lower section, while the floor levels of the higher section are offset by +800 mm.
Automatic Story Assignment: Doors and windows are assigned to the story where the majority (> 50%) of the element's height is located. Consequently, if more than half of the opening falls below the Floor Plan Cut Plane / Story level, the element is scheduled under the story below rather than the intended story.
Discrepancy in UI vs. Schedule: When selecting the opening in 2D/3D (or checking the Info Box / Settings dialog), the position is tied to its parent/host element (Wall), but in the Interactive Schedule, it lists a different story.
Current Workaround & Wish
My Workaround: I currently resolved this by creating an Expression-Defined Property (Property Manager) that calculates the vertical offset of the opening and overrides/evaluates the correct story location.
Wish / Request: Would it be possible to add an option or logic in Archicad so that door/window scheduling can strictly inherit the Home Story of the Host Wall (or allow users to choose between "Host Wall's Home Story" and "Calculated Geometric Story"), rather than being automatically driven by geometric cut planes and elevation? This would prevent openings in split-level designs from being listed on the wrong story.
Note
I have attached graphical screenshots from the project to illustrate the issue and the current behavior.
Czech original:
Popis problému
Při vytváření tabulek pro výpis dveří a oken dochází u vlastnosti Jméno domovské podlaží ke špatné hodnotě, než ve skutečnosti má být.
Důvodem je projekt, který má dva objektové celky a jeden je oproti druhému výškově odskočený.
Výška úrovně podlaží je nastavena na úroveň podlahy nižšího objektu a podlahy vyššího objektu jsou odsazené o 800 mm.
=> dveře a okna jsou přiřazena k podlaží, kde je větší polovina prvku, tedy pokud je pod rovinou řezu >1/2, prvek spadá do podlaží, které je pod domovským podlažím
=> po označení výplně otvoru ukazuje umístění dle konstrukčního prvku (stěna, deska,...), ale ve výkazové tabulce se liší
Řešení a prosba
Problém jsem vyřešil nastavením vlastností s funkcí, která dopočítává rozdíl umístění výplně otvoru a přepisuje tak umístění podlaží.
Bylo by možné tento problém s vykazováním nastavit v softwaru tak, aby se vykazování výplní otvorů řadilo dle umístění stěny a nebylo závislé na půdorysné rovině a pak u rozdílných výšek nebylo ve špatném podlaží?
Poznámka
Pro doplnění popisu problému přikládám názorné grafické přílohy z projektu.
Řezová rovina podlaží.pngVlastnost pro výkaz.pngPůvodní a nová vlastnost.png
Status
Submitted
with 6 Votes
Wish details
