The new Project Info text boxes being unadjustable is an issue for workflow in our office.
We use Project Info to make lists of autotext that generate on multiple sheets, sometimes this list can contain multiple lines of information.
The new Project Info text box that pops off the side is incredibly small and hard/frustrating to navigate when there are more than a few lines of information.
The old method of having a separate pop up box that was able to be resized to see more information on the screen was significantly better.
I can understand where this new box would be beneficial in some cases, perhaps the project info could have the little arrow that pops the box off to the side, but is also able to be double clicked on to open a new window for larger amounts of Project Info.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
