Roof Tool: Symbolic Overhead
Guru
Hi all,
This wish is for Symbolic Outline for Roofs, or for the current Outline setting to work the same as it does for Beams.
When working with sloping sites Relevant Storey display settings work against you meaning that all of your walls and columns often need to be modelled seperately for each storey and set to Home Storey Only - Symbolic Cut, and beams often need to be set to Outlines Only in order to get a consistent display along your slope. But when it comes to the roof tool for either actual roofs or ramps, there is no equivilent as the current Outlines Only setting for it is still elevation dependant, even though it hides half the settings it uses...
Related thread: https://community.graphisoft.com/t5/Modeling/Roof-shown-as-overhead-with-outline-selected/td-p/34195...
Ling.
Status
Submitted
with 3 Votes
