Currently, you can only set line weights via a general pen setting based on a color grid (where a specific color corresponds to a specific line weight). It would be preferable to set line weights individually for each element using a thickness parameter. This would also free up a larger color palette for color-based drafting.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
