Wall Schedule Annotations
Sa_Chugg
The ability to generate wall schedules that itemise wall types used within the project is a great tool for detailing wall types for construction.
However, the limitations of the schedule outweigh the benefit on using it (for example, there is no option in the scheme settings to list each composite layer and it's thickness). Instead, the recommended "work around" is to manually model each wall within the project and label it using using the Skin List Label.
I wish that the wall schedule could:
1. provide a 3D Plan View (rather than a "2D Plan View") that allows materials within the composite wall to be tagged with an active label, and
2. list the composite layers (like the Skin List Label does).
Example of wall schedule with desired labelled wall material shown in red:
Example of Skin List Label used for the same wall as a "work around" after manually modelling each wall in the project:
Status
Submitted
with 2 Votes
